Author Topic: oil leak  (Read 3260 times)
Offline El__burro
Re: oil leak
« Reply #15 on: January 22, 2016, 06:30:28 PM »
thanks, i was thinking of doing it myself using the spare cable in the picture. Actually that could be not the rev but the speedo cable.
how can I tell?
thanks
el__burro
Offline Chris400F
Re: oil leak
« Reply #16 on: January 22, 2016, 06:58:13 PM »
how can I tell?
Length is the obvious thing that springs to mind but not sure how different they are. I'd guess the speedo cable is longer.
If you fit a cable in the hole where will it go to? Surely a plug is a much neater and probably better solution as it will properly seal the hole.
Offline El__burro
Re: oil leak
« Reply #17 on: January 23, 2016, 05:06:40 PM »
The cable fits best with the speedo drive, in the tacho whole its a bit loose.
Anyway, i have contacted the (only?) seller for the blanking cap above but still waiting on an answer.
thanks
El__burro
