Author Topic: For the car restorers here - windscreen insert tool.  (Read 850 times)
« on: January 08, 2025, 07:52:32 AM »
Came across this tool that I have had for many decades , I used it to re-fit front & rear screens on my various Minis back in the 1970's.
It has a variety of fittings for other makes/models/types of screen rubbers with plastic type insert strips
Free to a good home, just postage cost that will easily be well under £10 via Royal Mail.
I will never use it again, too good to go in the bin. PM me if you want it.
.PXL_20250108_074428353 by Macabe Thiele, on Flickr
« Last Edit: January 08, 2025, 10:34:02 AM by McCabe-Thiele (Ted) »
Re: For the car restorers here - windscreen insert tool.
« Reply #1 on: January 08, 2025, 10:50:11 AM »
First impressions thought it some sort of puzzle!😜 Bound to be of use to someone.
1974 Honda CB550K1. Undergoing restoration
1978 Honda CB550K3.
« Reply #2 on: January 08, 2025, 11:43:04 AM »
Isn't there a Mini (not BMW) version of this site out there somewhere Ted?
2022 Tiger Sport 660
« Reply #3 on: January 08, 2025, 12:10:22 PM »
The attachment fitted to the handle  is for a BL Mini, back in the day most windscreens were fitted using a strip insert. I believe the various end fittings cover pretty much every profile insert from the 1960-1980s until bonded screens took over.
« Reply #4 on: January 08, 2025, 01:15:45 PM »
I could have done with that back in the Seventies when I built a GP beach buggy. Being on a tight budget I pushed the windscreen rubber and strip in with screwdriver blades. Very fiddly and time consuming!  🙄
« Reply #5 on: January 08, 2025, 05:48:44 PM »
Probably on FB, if it's of no use to a member I'll put it on flea bay.
« Reply #6 on: January 08, 2025, 08:11:30 PM »
So many now are bonded Ted but was invaluable in its day
« Reply #7 on: January 08, 2025, 08:45:27 PM »
I still remember using it on my Mini, I used neat washing up liquid on the rubber surround. The hard bit was the first two inches then it just zoomed round once I got going.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #8 on: January 09, 2025, 08:24:02 AM »
Hi Ted,
I'm still a member of a forum where you might find someone needing that tool.  It's
www.theminiforum.co.uk
As you say, too good to dump and someone will need it.  I have one too - bought in the late 60's but still have a Mini of course (free from BMW contamination)
Ian
