Author Topic: Finally fitted the 400 clutch cable guide!  (Read 783 times)
« on: October 01, 2024, 05:32:06 PM »
I've had my SS clutch guide bracket for a good six months as they were hard to find.  I had a members home made part as a temporary fix attached with a cable tie to a right angle bracket.
I had retained a copy of where it shoud fitted so used this old posted photo for reference - the job actually went quite smoothly for a change.
.400F - Clutch Cable Guide 2 by Macabe Thiele, on Flickr
Offline Athame57
    • SeaWitch Artist
Re: Finally fitted the 400 clutch cable guide!
« Reply #1 on: October 02, 2024, 10:28:18 PM »
A splendid feat of engineering!  ;D
1978 CB400F2 called Elen.
« Reply #2 on: October 03, 2024, 09:24:24 AM »
I gave up trying to do the job without removing the rear strap loop on the tank - I managed to undo the bolt but getting the bracket in place whilst fighting the clutch cable was a losing war. I'd not be much of a keyhole surgeon.
Drained the tank  then with the rubber part uncliped I used a rubber block  to support the tank - easy. I then spotted something else that needed tweaking so removed the tank anyway.
« Reply #3 on: October 04, 2024, 01:40:59 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #4 on: October 04, 2024, 05:09:15 PM »
It's all back together ready for winter storage.👍👍👍
If I get a warm day this month I'll give the 500 a run.😁😁😁
