Author Topic: CB550 refurb  (Read 22440 times)
Re: CB550 refurb
« Reply #180 on: January 28, 2025, 10:09:47 PM »
Main function of the carpet Ted is put there for the build, giving the frame and engine protection from getting the paint scuffed off. Great for protecting all the components, chrome etc. Now that the bike is rolling the carpet will be removed until the next build. 👍
1974 Honda CB550K1. Undergoing restoration
1978 Honda CB550K3.
Re: CB550 refurb
« Reply #181 on: January 29, 2025, 08:22:53 AM »
Lovely bike. I was to comment on those blinkers, but then I read Bryan's comment. I couldn't beat him. :D
Shame about the US frying pan indicators
Re: CB550 refurb
« Reply #182 on: January 29, 2025, 10:34:32 AM »
Have you got a red carpet for "Launch Day" when the bike is finished?
Re: CB550 refurb
« Reply #183 on: January 29, 2025, 12:12:28 PM »
Maybe a skip in case it all goes pear shape Gareth! 😳
1978 Honda CB550K3.
Re: CB550 refurb
« Reply #184 on: January 29, 2025, 01:19:04 PM »
That'll never happen!  🤞
Re: CB550 refurb
« Reply #185 on: January 30, 2025, 10:40:34 AM »
So here’s the confession - after filling the carbs with fuel and quickly discovering I hadn’t closed No3 carb drain screw 😡 I pressed starter button and turned over to nothing more than banging and cracking and misfire I quickly realised something is not right. I kind of ran out of time and left it til later in the day buying myself some thinking time. My instinct was to check valve timing which I did and resulted in the realisation that they were not set right. I had set the valves when I assembled the top end but had set the valves on the exhaust TDC stroke and not the compression TDC 🫢. Anybody tried that? Just me then! After setting them correctly all is well, fired up immediately and running well maybe try a carb sync see what like when I give it a right heat up. Slight leak at camshaft end cap mounting bracket. Is these aluminium sealing washers still available?
1978 Honda CB550K3.
Offline nairb
Re: CB550 refurb
« Reply #186 on: January 30, 2025, 11:09:13 AM »
I always find the first 20+ miles on a rebuilt engine a nervous/fraught time. Especially on a 2-stroke, Best have a change of underwear tucked into the tool kit as well.
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2, gt380 Kz750 twin, cb360K0 and an old working bicycle
Re: CB550 refurb
« Reply #187 on: January 30, 2025, 12:02:55 PM »
I did that on my CB175 Johnny.
“We are not alone”…
2022 Tiger Sport 660
Re: CB550 refurb
« Reply #188 on: January 30, 2025, 12:33:04 PM »
Lovely work goinng on there Johnny and in a nice big garage.
1976 Honda 400/4
Re: CB550 refurb
« Reply #189 on: January 30, 2025, 12:49:36 PM »
First start up rides always fills me with apprension, I remember one of my early runs on the 400 during its two cylinders only period (plug leads not in correct order) as I'm going up a fair hill the engine started to die. I pulled onto the pavement to look on my phone for breakdown recovery. That's when I turned the petrol tap to R, it flooded a carb, tarmac was stained, I thought for a moment it was engine oil. Rocked the bike, rode home on 2 cylinders. Wow was it a different bike when I switched the leads. Rookie mistake left coil to one &  two, right coil to three & four. I beat myself up with that mistake.
