Author Topic: Fuel stabilizer - serious test!  (Read 4165 times)
Offline Mikep328
Re: Fuel stabilizer - serious test!
« Reply #30 on: December 22, 2024, 09:19:28 PM »
I get a bit annoyed at internet "experts" that test something in a way that has little to do with its actual use and then make pronouncements based on that.  In this case, Stabil (and similar products) is a fuel stabilizer.  The TEST of it is simple, can it "stabilize" or "preserve" (or whatever the proper term is) fuel so that it will still function properly after extended storage.  With three vehicles sitting with fuel in the tanks for five years (none more than half full) and starting/running with no issue, clearly Stabil does what it is supposed to do - even better than Stabil claims (up to two years).  As I have said before, I'm sure other similar products will do the same but Stabil is the only one I have used.
« Reply #31 on: December 22, 2024, 10:14:53 PM »
Just be grateful that you are still alive. When you play with petrol, the vapour given off can penetrate your clothing. If the liquid petrol catches it will just burn, but the vapour ignites instantly with a "whoosh". The flame from the vapour shoots up past your face and you gasp in shock, breathing in the flames. Goodnight cruel world.
It was an egg cup full outside and down wind. I'm hardly going to end up in a fireball I'm not an idiot. It was done simply to prove that it was the fuel at fault . As for people getting slightly annoyed at so called internet experts, it's just an opinion. Everybody is entitled to an opinion right or wrong. So please try not to be annoyed. Moan over.
« Last Edit: December 22, 2024, 10:21:00 PM by royhall »
