Author Topic: Crankcase starter gear shaft entry hole.  (Read 298 times)
Offline Dolomite_
« on: June 05, 2024, 05:59:08 PM »
Bit of a brain fart, and I cant quite tell from the pictures I took. In the picture, the hole where the starter gear shaft is inserted, what covers it up? is there a bung or does something else go in there?
« Last Edit: June 05, 2024, 06:35:10 PM by Dolomite_ »
Offline Deano400
Re: Crankcase starter gear shaft entry hole.
« Reply #1 on: June 05, 2024, 06:19:23 PM »
You say "In the picture", did you intend to attach a picture?
Offline Dolomite_
« Reply #2 on: June 05, 2024, 06:36:23 PM »
Now there's a picture, the link didn't work for some reason
Online Laverda Dave
« Reply #3 on: June 05, 2024, 06:58:13 PM »
No, nothing else goes in there. The shaft is retained by a 6mm bolt and a lock washer, make 100% sure you replace the lock washer otherwise the shaft retaining bolt may escape if it comes loose and drop into the gearbox.
« Last Edit: June 05, 2024, 07:02:48 PM by Laverda Dave »
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Dolomite_
« Reply #4 on: June 05, 2024, 07:11:36 PM »
So nothing closes up that access hole? I'm surprised oil doesn't make its way out.
« Reply #5 on: June 05, 2024, 07:39:26 PM »
There is supposed to be oil either side of that web
Offline Dolomite_
« Reply #6 on: June 05, 2024, 08:51:38 PM »
Yep, I completely forgot that the clutch is there and the clutch is in the engine oil... I'm so used to dealing with just the crank cases at the moment.
