I use ATF, Basic Dexron,as my car used it,Nice even,smooth feeling when riding, Sent from my SM-A546E using Tapatalk
Quote from: Johnwebley on June 03, 2024, 09:53:29 AMI use ATF, Basic Dexron,as my car used it,Nice even,smooth feeling when riding, Sent from my SM-A546E using TapatalkWhen you say basic Dexron is that 1,2, or 3 all old specs pre- synthetics?
Quote from: McCabe-Thiele (Ted) on June 03, 2024, 10:24:35 AMQuote from: Johnwebley on June 03, 2024, 09:53:29 AMI use ATF, Basic Dexron,as my car used it,Nice even,smooth feeling when riding, Sent from my SM-A546E using TapatalkWhen you say basic Dexron is that 1,2, or 3 all old specs pre- synthetics?The newest ATF Dexron oil is backward compatable. Anything that took Dexron II will now take Dextron III. All oils of the same grades are designed to be mixed as per industry standards.
GRR... Using the correct size box end wrench I could not loosen either of the top fork bolts! When I go to the bike next (a 1/2 mile walk from our house) I'll take a socket set but that will require removing the handlebar to get access. I can't imagine that the fork bolt is supposed to be anywhere near as tight as these are. Maybe I'll try the wrench again and give it a good whack with a rubber mallet to see if I can break the bolts loose without removing the bar. Out of curiosity I looked in the service manual to see if there was a torque setting for the fork bolt, wondering if it was supposed to be much tighter than I think but I couldn't find a setting for that bolt.Oh well, if things went smoothly it would be boring.
