Author Topic: Headlight reflector  (Read 1319 times)
Offline DomP
Headlight reflector
« on: May 26, 2024, 06:26:01 PM »
Is a CB550 and 750 reflector the same? Mine on my 550 is a Stanley 001-1217 but a previous owner has fitted a strange bulb that has meant they've used an oil seal to hold it in place.  Can I retro fit an H4 Led to it?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Headlight reflector
« Reply #1 on: May 26, 2024, 06:36:06 PM »
My 500 headlamp is  a standard UK style 7" unit.
It has the three lugs similar to those on the old sealed beam headlights.
I fitted a Land Rover Defender 90 type LED headlamp unit but pretty much any old style 7" headlamp will fit.
Offline DomP
« Reply #2 on: May 26, 2024, 06:53:29 PM »
I was more wondering I could retain this reflector but retro fit an H4 led Ted
1975 XS650B
« Reply #3 on: May 26, 2024, 06:58:21 PM »
I don't know the answer,
But I have a H4 bulb,in a non standard reflector,
Fitting Cebie or similar used to be an upgrade
Offline Skoti
« Reply #4 on: May 26, 2024, 07:17:16 PM »
This is the LED that I fitted to the original reflector on my F1 which is a direct replacement for the original bulb that you have (P45T).
https://www.classiccarleds.co.uk/products/compact-direct-fit-p45t-r2-led-hi-lo-beam-conversion-5-15-volts-410-423?_pos=3&_sid=a1490a3e3&_ss=r
While you're at it I recommend updating the side light bulb as well (BA9S).
It's very bright and would almost suffice as a day running light.
https://www.classiccarleds.co.uk/products/ba9s-bright-white-200-lumen-t4w-233-led-drl-sidelight-upgrade-bulb-llb233-llb989?_pos=3&_sid=db90a2d79&_ss=r
Hope this helps
Skoti
1976 Honda CB750F1
Offline DomP
« Reply #5 on: May 26, 2024, 07:36:34 PM »
Thanks Skoti, that looks the best and easiest option.  Mine must be missing a retaining clip or something for there to be an oil seal used to hold the P45T bulb in.
One last question, did you use a 4300k bulb? 6000k might be a bit blue?
1975 XS650B
« Reply #6 on: May 26, 2024, 07:38:34 PM »
That is a standard car bulb and there is an H4 equvalent, i will see if i can find a number for you cos im bored
Offline Skoti
« Reply #7 on: May 26, 2024, 07:44:30 PM »
Yes, I used the 6000k bulb and it's a bit blue. Maybe the warm white would look a bit better on an old classic motorcycle but that's your choice.
BTW
there should be a spring below the headlamp bulb retaining cup to hold the bulb in place.
« Last Edit: May 26, 2024, 08:00:27 PM by Skoti »
Skoti
1976 Honda CB750F1
« Reply #8 on: May 26, 2024, 07:45:36 PM »
Are these the bulbs, pic of halogen
« Reply #9 on: May 26, 2024, 07:49:40 PM »
Pic of original
Offline Skoti
« Reply #10 on: May 26, 2024, 07:52:22 PM »
Bryan,
I first made the mistake of fitting a normal H4 halogen bulb, and found the charging system would not cope well when driving in towns etc.
I have a volt meter fitted and noticed the voltage drop below 11.5 volts when waiting at traffic lights and road junctions.
I switched back to the standard 410 bulb to rectify the problem, but now have an LED which obviously has an even lower power draw.
Volt Meter:-
https://photos.app.goo.gl/GQUC6TZKV9SkJBCh9
« Last Edit: May 26, 2024, 08:10:59 PM by Skoti »
Skoti
1976 Honda CB750F1
Offline DomP
« Reply #11 on: May 26, 2024, 08:19:34 PM »
Thanks Bryan, I've got an original style globe type bulb fitted currently
1975 XS650B
« Reply #12 on: May 26, 2024, 08:22:59 PM »
Back in 76 as a young(er) rider i fitted a h4 unit and with lights on stayed 1 gear lower than in daylight, not forgetting in UK we can switch lights off
« Reply #13 on: May 27, 2024, 08:15:48 AM »
Sorry I slightly misunderstood your question.
As has been said the current draw of a modern H4 Quartz Iodine bulb might be a tad high, the other consideration is the dip pattern cut off  might not be good.
I am a fan of fitting an LED bulb as I did originally on my 400. Beware of cheap ones off eBay I had one that stopped working after just a few on & off cycles.
I sent a message to LED classics to find the right bulb as the important heat sink can cause issues of being too long when fitted either inside the light unit or outside. Again as the reflectors were designed for the build design Honda used there will always be a compromise in terms of scatter and dip cut off.
If you search the posts Oddjob did a lot of research on this with photos of the result of using different bulbs. I suspect like moths are attracted to light we are attracted to big Lumen numbers. In the end that's why I fitted a  complete headlight designed from the off for LED only use so the reflector gives a good dip cut off and a nice high beam plus low current draw.
« Last Edit: May 27, 2024, 09:47:39 AM by McCabe-Thiele (Ted) »
Offline deltarider
« Reply #14 on: May 27, 2024, 08:24:17 AM »
Usually the lens will have 'H4' in the center of the glass, if the reflector is fit for halogen bulbs.
The socalled 'charging shortcoming' of the these bikes is an urban myth. I've had a 55/60 Watts bulb all those years - my model came standard with it! - and never had a problem, not even with 3 Ohms coils and a transistor ignition. Every ride I return to the garage with a better charged battery than I took of with. 44 years of experience here. I recommend Philips. The Extreme Vision Moto H4 and Osram Nightbreaker came out best in tests and that Philips was especially developed for motorcycles and can cope with vibrations up to 10G.
« Last Edit: May 27, 2024, 09:43:42 AM by deltarider »
